HELP!! Traction Control light flashes!
Old Aug 11, 2012 | 11:27 AM
hypeiv's Avatar
Originally Posted by 1HIJK
I did install my self and the steering wheel is off center. About to get alignment done. Hopefully that helps. Thanks for the input.
this is the reason for the problem... check out the project-jk webpage... you can recenter your wheel easily... the aev has a mode to help.
It is the steering wheel diagnostics or something... park with your wheels straight (wheels not steering wheel) and have someone sit in the drivers seat. Plug in the AEV with the diag mode. It will show either the left or right indicator to show you how far you off.
Climb under your jeep and unbolt the two bolts locking the turn buckle... its way up there behind the plastic air dam skid thing. Rotate that and have your friend tell you if the steering wheel is getting better or worse. If its getting worse, start rotating it the other direction, If its getting better then keep going until your friend tells you the blue high beam light comes on and stop there. Then tightnen up and you are done.
http://project-jk.com/jeep-jk-write-...-end-alignment
http://www.youtube.com/watch?v=gCMiAkgY8m8
Old Aug 11, 2012 | 01:00 PM
1HIJK's Avatar
Thanks for all of the input! I went up to the dealership I used to work at and they let align my rig myself. Centering the wheel is what fixed the problem! Now to get it dirty!
Here is the rig as it sits now!
ID:	352930   Click image for larger version
