Herculiner???
Old Jul 20, 2012 | 01:22 PM
TyJK9's Avatar
Wow that turned out great. I'm going to take your advice and look into the product you used. Thanks for the links and advice!!
Old Jul 20, 2012 | 04:13 PM
truckie515's Avatar
I did my tub with the Herculiner about a month ago. It's all in the prep, used 20 grit to ruff it up a bit then roll it on. I used one gallon for two coats. The coats were pretty thick in high traffic areas. I let it dry about four hours between coats then dry over night before driving it. I did not remove the center consul but everything else came out.
I have been really please with it so far. No odor that I have noticed but then again I have not had the top or doors on since I did it. No problems cleaning the tub out, just wash it like outside and pull your plugs.
Over all pretty happy with it.
Old Jul 20, 2012 | 04:57 PM
Jeeper'08's Avatar
Originally Posted by newbiejeeper
Herculiner is not uv stable and tends to turn chalky after a few years. I have done a lot of research on this recently as I am about to paid the tub of my two door. I choose Monstaliner and ordered my kit earlier this week. It's almost the same price as Herculiner. Monstaliner is running a free shipping and free chassis saver quart with all online purchases. You just need to find magnetman (user name) on one of the other forums. He has a link to the codes you need to enter at check out.
Just looked a little at Monstaliner.. Seems like a good product and cheap, the only disadvantage is its a roll on. Gonna make it a lot harder when you are trying to paint those tricky places..
Old Jul 20, 2012 | 05:31 PM
newbiejeeper's Avatar
You can spray it or roll it on. I will be rolling mine on.
Old Jul 20, 2012 | 05:42 PM
TexanJk's Avatar
I mostly read on the forum, but am compelled to comment (ha!). Last September I took a gallon of herc and covered the tub. In Houston in September it is brutally hot but the humidity is a plus for cure time. The more humidity the faster the cure. Took everything out, removed the sound/heat barrier and went to town. It's all in the prep, seriously. The gallon kit comes with a small brush and small roller. You can spray it, but I don't have a compressor. No odor after it cured and I wash it out just like the outside. I don't care about fading, as my JK is silver. Besides I'd just armorall it if I was that concerned. I posted some pics on a thread, you'll just have to search it. Just follow the instructions to a 'T' and it will come out nice. Best part is, if a patch comes up that wasn't prepped good or worn off, you can sand again and reapply. Even if later you realize you want thicker, it bonds to itself. It is a rougher compound when it cures, but pretty tough. Also I suggest running a carpet mat or rubber one just to cut down on the heat a little. But of coarse it hot as hell where I'm at! Hit me up if you have questions.
Oh yea, taking my time and getting small tools I didn't have, it took me a full day and a half. But it's right.
My .02 cents...
Old Jul 21, 2012 | 07:55 AM
Jeeper'08's Avatar
I know, the roll on seems a bit easier to deal with.. But what are you gonna do when you get into those tight spaces and tricky corners?
Old Jul 21, 2012 | 04:31 PM
DSOY's Avatar
I'm going to price out linex on monday, just for laughs.
Old Jul 21, 2012 | 07:48 PM
Rooster76's Avatar
That's some good stuff if you can afford it. When I did an estimate at the Line-X by me he said it would be $500 if I did all the prep and drove it in with just the driver seat.
Old Jul 24, 2012 | 12:32 PM
Jeeper'08's Avatar
Dang, that's a good price!
