How Big Can My Tires Be?
Old Jul 27, 2010 | 11:43 AM
Olean NY Jeeper's Avatar
Originally Posted by terribad16
Oh alright, now I finally get that... Well I could afford the teraflex lift right now, but not the tires yet... Will putting the lift in before the tires make my jeep look funny, or should I just wait until I can put both on at the same time??
If you have the stock 32 inch rubicon tires it will look fine. If you have the street tires I would save your money and upgrade all at once.
Old Jul 27, 2010 | 11:56 AM
Pluke the 2's Avatar
It won't look funny. but you gain real inches when you put new tires on.
I would skip the leveling kit if in the future should you throw on new rubbers .
Old Jul 27, 2010 | 12:19 PM
Default How Big Can My Tires Be?
Well I was putting in the kit to make room for new tires. Cause i have a stock X and I didn't think any bigger than the factory tires could fit
Old Jul 27, 2010 | 12:32 PM
Full-Traction Suspension's Avatar
Former Member
you can fit 35's if you cut your stock fenders and add some longer bump stops
Old Jul 27, 2010 | 12:53 PM
Hmmm... Well see I don't know which is better to do. Cut that stuff, or just put that teraflex lift in it.
Old Jul 27, 2010 | 02:12 PM
Originally Posted by TX2PR2SC
It's all what you like, but if you aren't skilled/patient a homemade fender chop can look very...shitty. The teraflex kit is cheap, gives you lift and will maintain a professionally installed look to your Jeep. Even with stock tires/rims it's not so much that it looks terribly different.
well the chopped fenders will eliminate more rub then the leveling kit.
Old Jul 27, 2010 | 02:17 PM
Well I've never chopped a fender before, so I'm pretty sure i would make it look shitty
Old Jul 27, 2010 | 03:28 PM
Rubi Russ's Avatar
you could always get a set of flat fenders and gain enough clearance.
Stock tires on 2.5" tflex on blue 4dr
Mine on 37"
Old Jul 27, 2010 | 03:30 PM
Mine on 37"
Oh okay, so another newb question. I can buy flat fenders??
Old Jul 27, 2010 | 03:39 PM
Rubi Russ's Avatar
You sure can. plastic or steel. I like the plastic ones they flex instead of sheet metal and body.
these guys keep climbing on my tires and running over my flares
