How Big Can My Tires Be?
If you have the stock 32 inch rubicon tires it will look fine. If you have the street tires I would save your money and upgrade all at once.
I would skip the leveling kit if in the future should you throw on new rubbers .
Originally Posted by Pluke the 2
It won't look funny. but you gain real inches when you put new tires on.
Originally Posted by Full-Traction Suspension
you can fit 35's if you cut your stock fenders and add some longer bump stops
It's all what you like, but if you aren't skilled/patient a homemade fender chop can look very...shitty. The teraflex kit is cheap, gives you lift and will maintain a professionally installed look to your Jeep. Even with stock tires/rims it's not so much that it looks terribly different.
Originally Posted by Rubi Russ
you could always get a set of flat fenders and gain enough clearance.
Stock tires on 2.5" tflex on blue 4dr
Mine on 37"
Mine on 37"
