How-To Spotlight: JK Shock Absorbers
Shock absorbers should be more than an afterthought. Start improving your ride right here.
Read the rest in the JK Forum how-to section. >>
I have a 2015 2 door rubicon with a factory 1” Llift.
I want to install a shock/suspension system where as when I load up the back or hook up the boat to take to the launch the Jeep won’t snag at the back end.
Was thinking of air shocks and an onboard dual action air compressor where I can firm up the shocks when under load and loosen off when not.
Any and all suggestions and advice is appreciated. With this system what are the advantages and disadvantages, pitfalls?
what would you advise then?
is there a make of compressor that does not add moisture?
if a air bag is rubber or silicone does moisture matter?
Canadian Jim
All compressors will push moisture, you could add an air dryer to the system but shocks should be filled with nitrogen. You could just plumb up a small nitrogen bottle to an air shock and fill it that way. The air bags won't care about moisture.
