How-To Spotlight: JK Shock Absorbers
Old Apr 4, 2017 | 10:42 AM
JK-Forum Editor's Avatar
JK-Forum Editor
Default How-To Spotlight: JK Shock Absorbers
Shock absorbers should be more than an afterthought. Start improving your ride right here.
Read the rest in the JK Forum how-to section. >>
Old Apr 11, 2020 | 06:38 PM
Canadian jim's Avatar
I have a 2015 2 door rubicon with a factory 1” Llift.
I want to install a shock/suspension system where as when I load up the back or hook up the boat to take to the launch the Jeep won’t snag at the back end.
Was thinking of air shocks and an onboard dual action air compressor where I can firm up the shocks when under load and loosen off when not.
Any and all suggestions and advice is appreciated. With this system what are the advantages and disadvantages, pitfalls?
Old Apr 12, 2020 | 06:53 AM
TheDirtman's Avatar
Have you looked at air bags? You should not fill a shock with air from a compressor as it will introduce moisture into the shock and it will corrode.
Old Apr 12, 2020 | 07:21 AM
that is great advise. Thanks. Had not thought of that.
what would you advise then?
is there a make of compressor that does not add moisture?
if a air bag is rubber or silicone does moisture matter?
Canadian Jim
Old Apr 12, 2020 | 07:32 AM
TheDirtman's Avatar
All compressors will push moisture, you could add an air dryer to the system but shocks should be filled with nitrogen. You could just plumb up a small nitrogen bottle to an air shock and fill it that way. The air bags won't care about moisture.
