Hypertech Update
Old Feb 5, 2009 | 08:34 AM
edwin907's Avatar
Default Hypertech Update
I've had the Max Energy programming on my Jeep for almost 5K miles.
I've been mostly happy with it, particularly with the corrected speedo.
Well for the second time I updated it via the internet last night and re-installed the programming.
The first time I updated it was right before I installed it and read here where at least one member had updated it recently and experienced better performance.
Well let me tell you, at least on the Premium setting this thing is way better.
WAY TO GO HYPERTECH!
Old Feb 5, 2009 | 08:47 AM
jeeperjkj's Avatar
Sounds good to me. I guess the 3.8 is livable, huh...
Old Feb 7, 2009 | 03:26 AM
JK-Q8's Avatar
question if i get it and program and then when i want to get it to service and remove the programing will the dealer be able to see that i have a programer?
Old Feb 7, 2009 | 05:30 AM
kflash's Avatar
I installed mine last November. Do you think I need an update?
Old Feb 7, 2009 | 04:00 PM
chasew's Avatar
I would like to know too!
Old Feb 7, 2009 | 04:04 PM
tambil68's Avatar
IMHO _ couldn't hurt right! You could also check on the version and see if its changed.
No they won't. It will make no difference at all if you reset it to stock. If you don't the problem would not be the dealership knowing you reprogrammed, it would be the slight chance that they flash an update and it isn't compatible with what the hypertech settings are, then you have a computer problem.
Old Feb 7, 2009 | 04:07 PM
jvalason's Avatar
If you return it to stock and they flash the computer then re-install the programmer again everything will be fine though right?
08 rubi's Avatar
yes dealerships can tell if u use a programer on your jk every time u change your settings the computers record it
Old Feb 7, 2009 | 04:14 PM
def9112's Avatar
Thanks just updated mine
Old Feb 7, 2009 | 06:33 PM
aldaman's Avatar
Updated mine, but I am the unlucky one...getting error message (see below)...Will have to call Hypertech first thing monday morning to get this resolved..As for now the JK is on stock setting
Board ID 19
Expected 23
" An unexpected error condition has occured" Contact Tech line
