I broke it!
I'm not an expert, but the fact that the shock didn't rebound and is still compressed while laying on the ground tells me you might need a new shock. It might have bent when it came loose. Anyway, I hope the bar pin does the trick.
I dont think those shocks are supposed to rebound as they are absorbers, if he had backed up at all I would check the lower as well as the upper mounting points for any damage. it could have just been compressed a lil and stayed there due to the mounting bolts not tight or just vibrated out. Red locktight will fix that.
Does anyone have a Skyjacker 7000 shock they don't need? Or the pin that goes in the top mount? I found a shop that had a stock pin, but the slot for the bolts weren't big enough. I guess the JK's have a larger size than TJ's. I had the pin welded, but I don't really trust it for off-road.
I dont have a shock, but I have a JK barpin. It is from a stock rear shock. You are welcome to it if works for you. Hit me up with a PM if you want it.
on the rubber grommet (suggest replacing that too) and tap it in with a hammer over a vise, done, no big deal, no conversions needed unless you want to go there right now.
Looking at your pic i think you have an other problem as well. When the shock is loose like that the red accordain boot should be totally extended and it is NOT. Think you have a bad shock now and need a new one.
