I broke it!
Old Mar 3, 2009 | 05:53 AM
  #21
SASQUATCH's Avatar
Originally Posted by jkkat
Looking at your pic i think you have an other problem as well. When the shock is loose like that the red accordain boot should be totally extended and it is NOT. Think you have a bad shock now and need a new one.
dang...good eye...maybe it busted up and locked causing it to rip out of it's mounting position
07Rube can you pull the shock in and out and just fine (of course with a lot of resistance...normal)?
Old Mar 3, 2009 | 07:41 AM
  #22
Kenya1's Avatar
FWIW, I believe that Currie sells reinforced bar pins.
Old Mar 3, 2009 | 07:53 AM
  #23
AZJeeper's Avatar
Community Favorite
I'd be guessing you broke your frame mount too. There are two bolts that hold the shock pin in place. If one fell out because it wasn't torqued down properly, the other probably came out less gracefully.
Have you been under to look?
Old Mar 3, 2009 | 08:00 AM
  #24
USAF_GroundRat's Avatar
Originally Posted by YellowToy
Good Point!
If you drink better beer this wouldn't have happened. Switch to Abita TurboDog & nothing will brake on you jeep.
I dunno... I kind of like my Jeep to come with BRAKES.
Drink Chimay or Fat Tire and nothing should BREAK on your Jeep... but if it does, you won't care.
Disclaimer: this poster does not condone drinking and driving.
Old Mar 3, 2009 | 02:42 PM
  #25
07 RBY's Avatar
Yeah, it moves just fine with not much effort.
Old Mar 3, 2009 | 02:44 PM
  #26
07 RBY's Avatar
Yes, I looked several times. After I got the pin welded, I had no trouble putting the bolts back in.
Old Mar 3, 2009 | 03:41 PM
  #27
PhreakMode's Avatar
I don't think that the people who are suggesting your shock is bad, understand that those are hydrualic shocks you have and do not rebound. Apart from you coming right out and saying they are SJ 7000 series shocks, they must have also missed the photo showing the shocks mount with the body down...
Your shock is fine.
Old Mar 4, 2009 | 04:05 PM
  #28
07 RBY's Avatar
I still need a pin.
Old Mar 8, 2009 | 11:07 AM
  #29
07 RBY's Avatar
Anybody listening? I guess I'm gonna have ti buy a new shock. Can I buy just 1? That's why I'd like a used one.
Old Mar 22, 2009 | 09:57 AM
  #30
07 RBY's Avatar
Never mind; I just put on bar pin eliminators.
