I want one
Old Jul 11, 2008 | 12:45 PM
seer1's Avatar
I saw AA say talking about something like this a while ago and at the time he was saying it was only for the Rubi. Now that I am receiving some enlightenment from you all (thank you very much BTW) about this, does this mean it'll cut my low (Sahara) to about 5.44:1?
As long as we're talking, will we have to alter our drive shaft?
I'm starting to feel a real need.
Old Jul 11, 2008 | 12:47 PM
muddpuppy01's Avatar
the auto would be 158.51 crawl ratio still a pretty good number
axle braking nnumber if you get on it my opinion
Old Jul 11, 2008 | 12:52 PM
low low would be 21.01 out of the case
with the additional length of the doubler you would have to stretch the front and cut the rear shafts
Old Jul 12, 2008 | 02:42 AM
Renegade's Avatar
From what I understand about this product (yes, I have personally contacted them) it takes the place of a factory adapter/spacer that is already between the tranny and t-case. No additional driveline mods are necessary.
Old Jul 12, 2008 | 04:18 AM
CrunchyOatmeal's Avatar
I am bummed that it won't work with a 6spd. I just got back from moab and the lower gearing would have helped a ton.
Old Jul 12, 2008 | 04:48 AM
jeeperjkj's Avatar
That's what I got from them, too. It's a bolt on mod w/ no additional mods required.
That being said, it might be enough to snap an axle which would necessitate a "mod" called new axles!
Your tcase + doubler ratio would be ~7.4:1 * your first gear * your axle ratio and that'll give you your crawl ratio.
Old Oct 2, 2008 | 06:32 AM
tgrt's Avatar
Former Vendor
I was thinking the same thing. I want this bad, because I like going slow. However, I don't want to upgrade the axles other than the components within. I already have chromoly shafts up front and 5.13 gears. I'll probably replace the rear axle shafts at some point too.
Old Oct 2, 2008 | 06:45 AM
Leedsfighting17's Avatar
thats gotta be able to supply some torque to the wheels huh? well maybe i'll have the funds some day to make my jeep grow up.
Old Oct 2, 2008 | 08:14 AM
RedneckJeep's Avatar
Originally Posted by yetibear
Just think about it, with a Rubicon, you could get up in the morning, start the Jeep, put the transfer case in 4 lo, the rubicrawler in lo, the trans in first, let it idle off, go back inside, make coffee, have breakfast, take a shower, and if the little lady is willing, well you know.......and still catch the Jeep, before it gets to the end of your driveway.
There is part of me that wants one, and another part that says thats a little to slow for even me.
I know you're jokin, but check this out. This fellow built the slowest 8N tractor in the world. You could LITERALLY do EVERYTHING that you described. It crawls along at 12 inches an hour.
hxxp://www.marvinbaumann.com/fourtrans.html
Old Oct 2, 2008 | 08:20 AM
TONKA's Avatar
That sucks that this is only for the Auto.
