Immediate help needed!!!!!!!
Old Jan 7, 2009 | 05:08 PM
Default Immediate help needed!!!!!!!
Anyone on here know how to get the pinion nut off when swapping out the rear driveshaft????
I have a je reel 1310 and i cant get this damn thing off!!!!
Old Jan 7, 2009 | 05:13 PM
wayoflife's Avatar
JK-Forum Founder
an impact wrench is the easiest way to get it off. otherwise, you'll need a long breaker bar to do the job. a pipe slipped over your wrench will do the trick as well. if you have someone stepping on the brakes while you do this, it'll help keep your jeep from rolling and will maximize your efforts.
jkexpeditions's Avatar
90psi through an impact
Old Jan 7, 2009 | 05:18 PM
Doing 120 through an impact and it wont even budge.
Old Jan 7, 2009 | 05:21 PM
Wow. Mine slid off with the impact. Well, I guess I'll second the pipe extension on a breaker bar then. Maybe soak it with PB Blaster over night? Good luck.
Edit: Maybe, hit it with a torch to heat it up a bit?
Old Jan 7, 2009 | 05:32 PM
no torch and when i put brake on with breaker bar it just turns one side of the axle????
Old Jan 7, 2009 | 05:36 PM
dlud51's Avatar
Hmmm Not budging with an impact wrench or with the wrench trick....no torch...
How about MAP Gas??? Do you have a bottle of that handy??? If not it's cheap & may do the trick....
I know how frusterating that sh*t can be....keep trying brother and let us know!
Old Jan 7, 2009 | 05:37 PM
sgmrock's Avatar
Are you going the right direction? What impact wrench are you using? Is it oiled?
Old Jan 7, 2009 | 05:38 PM
jpp's Avatar
jpp
I have found that if something can move when I am using an impact wrench, it will absorb most of the impact. You might try to clamp a bar to the yoke and brace it tight against something solid. This way the impact of the gun is not lost in the slop of the gears, axle splines, brakes, etc... I hope that makes sense.
IPvFletch's Avatar
WD-40 + Lighter = Torch
YMMV
Other ideas?
Drop it while applying moderate pressure with the wrench?
Firecrackers, like an M-1000 (the $0.50 ones not a honkin stick of dynamite ok?) right next to it. The shock may jar it loose - it shouldn't damage it (I couldn't imagine how it could)
Yell at it?
