Install Problem on rock krawler 3.5 x factor system
Old May 13, 2012 | 07:38 AM
silverbackjk's Avatar
Default Install Problem on rock krawler 3.5 x factor system
I just installed a rock krawler 3.5 x factor system and an having a problem with the front sway bar hits in the front coils. We measured all the front control arms to rk specifications. the left side hits the coils and the right side is less .5 inch away. Anyone have any info on this?
Old May 13, 2012 | 07:54 AM
FlameRedJK's Avatar
Haha you must have missed the thread on this last week.
You mean like this?
Apparently it's normal...
Got my install done at EVO...they said they contacted RK and they said it was fine....
Passenger.
Driver.
As I've said before, I've abused this suspension quite a bit in the past few months and it performs like a champ...Articulates like a mofo!
Old May 13, 2012 | 09:02 AM
You mean like this?
Passenger.
Attachment 316246
Driver.
Attachment 316247
mine actually touches the coil if i stuff the right front tire the link gets caught on the coil.
Old May 13, 2012 | 10:31 AM
FlameRedJK's Avatar
Hmm, mine touches ever so slightly, never had that issue though...
Old May 13, 2012 | 12:43 PM
Has anyone had this issue
Old May 13, 2012 | 01:25 PM
Robsmst's Avatar
With their warranty. Maybe we should go wheel it and see if it binds or not or if it just scrapes really bad.
Then just keep using warranty to replace link and spring every few years?
Old May 13, 2012 | 04:02 PM
gfe jeep's Avatar
Originally Posted by mpkelley20
I just checked mine and this is what they look like. I had it professionally aligned after the install.
Passenger side
Drivers side.
Mine looks like this after an alignment. Waiting for a problem that hasn't appeared yet!
Old May 13, 2012 | 05:47 PM
cajun01's Avatar
Set your links at 24" and don't worry about it
Old May 13, 2012 | 05:53 PM
SSmileys12JKU's Avatar
Glad I found this, havent done full flex yet but my drivers side is closer than my passanger side too. Double checked my measurements, no issues as of 1500 miles.
Old May 14, 2012 | 02:37 AM
rickc309's Avatar
What's an explanation for this? Is this just a RK issue? Are the coils RK use larger diameter or are the front arms too long? I'm getting ready to order a 3.5 max travel and I'm interested in finding out why were seeing this with their kit.
