Installing Fox Bump stops for front axle
Old Feb 10, 2014 | 10:30 PM
tnt008's Avatar
Default Installing Fox Bump stops for front axle
I have a 3.5" RK mid arm flex system coming, pairs with Fox 2.0 shocks. Decided to pull the trigger on 2.5" stroke Fox bump stops as well.
Now, my question is... Are most people installing these bump stops inside their coils up front? Is this the only place for them to go? Will I need any additional hardware to put them in my coils?
Thanks.
Old Feb 10, 2014 | 11:11 PM
ronin2120's Avatar
Vet Army
Yes they need to install in the coil and you will need to cut the cup at the bottom. I used rotozip with cutting wheel due to the tight space. I attached some pics for a reference.
ID:	530179   Click image for larger version
ID:	530180   Click image for larger version
Old Feb 11, 2014 | 10:03 AM
tnt008's Avatar
And the rear ones???
Old Feb 21, 2014 | 10:32 PM
tnt008's Avatar
Bump...
Anyone have any pictures of rear mounted Fox bump stops. Do you need a bracket.
Old Feb 22, 2014 | 03:41 AM
ronin2120's Avatar
Vet Army
The rears mount on super easy it uses two bolts to secure them in place.
ID:	532586   Click image for larger version
Old Mar 31, 2014 | 07:53 PM
tnt008's Avatar
Is this flexed? Or sitting level? Because if your sitting level... theres not much room for up travel is it?
Old Mar 31, 2014 | 08:27 PM
36Fan's Avatar
You might want to do a bit more research,cause those pics are Teraflex speed bumps. Fox Bumps are mounted differently,specially the rears.
Old Apr 1, 2014 | 01:12 AM
PET77's Avatar
How do you actually assess required bumpstop height with these speedbumps on?
Old Apr 1, 2014 | 01:52 AM
kjeeper10's Avatar
Vet Army
You guys are seeing them at their extended height. I'm not sure how they work. If there is a solid height or not.
Think of them as another shock extended/collapsed lengths.
Old Apr 1, 2014 | 12:09 PM
tnt008's Avatar
I don't know about that. Look how much shock is left. And it looks like theres only an inch or two between the old bump stop and the Teraflex. Just don't look right to me.
