Instead of death woble...OUCH!
The photo is proof that drilling a hole and welding it up caused it to be weaker. Look at it like this. If you drilled a hole in a 20 foot pipe, welded it up, bent it till it broke, and it broke exactly on that weld, the hole/weld was the problem. That is exactly what we are seeing here. Had the hole not been related to the issue at all, it would not have broken at dead center of that hole. The odds of it just happening to nail that hole dead on are very small.
If the hole was not de-burred properly it can cause a micro fracture that can spread. On aircraft all holes are deburred just because of those issues. Anyone that works with metal on aircraft will tell you every rivet hole that is drilled is deburred.
I just went through a front housing replacement. I wouldn't replace stock with stock nor would I entertain putting another D30 in. The cost isn't going to be much more to upgrade. I just dropped in the Teraflex Tera44 for $3200 installed.
The cost is absolutely huge when compared to a $200 - MAX $500 d30 from Craigslist.
Seems like a good price. Where did you find that?
Insurance came through and wrote me a nice check. They are calling it collision. The agent had never seen anything like this broken Dana 30 of mine.
Now, on to axle shopping.
I want an aftermarket Dana 44 replacement for my factory Dana 30 and am looking at Tera Flex and Dynatrac.
I am considering having the ARB locker installed in the front while I am at it. Why not?
I'll need axle shafts but apparently I can re use the outer knuckles and brakes. Any suggestions on axle shafts? I am thinking 30 spline Ten Factory axles might be decent and fairly affordable.
Suggestions?
Suggestions?
