Insulation
Old Feb 19, 2015 | 07:57 AM
2climbbig's Avatar
Originally Posted by 101gargoyles
Hood blankets and vented hoods
How does anyone think that a 4 sided compartment open on 3 sides and the bottom....with a high speed fan in front can hold heat any better than if the hood is completely removed. Now my head hurts from banging it against my desk. The fan is only there to cool the rad when not moving forward
Well, actually, heat is trapped between the wheel wells and the hood. The hotter air is radiated or pushes its way up and tumbles. This causes a cushion that prevents air racing past from coming up into the engine bay. While air is always moving and hot air is always escaping, the air temp inside the engine compartment will always be hotter. While I am not arguing how effective a blanket is on retaining heat. It certainly isn't helping.
Also, its has been tested repeatedly that a vented hood reduces heat in the engine compartment. Car manufactures could careless as a vented hood also means reduced aerodynamics and in turn reduced mpg. Performance vehicles will factor intake temps into the equation by moving the intake port near the wheel well or other areas where they can grab cooler air.
