JEEP JK 3.8 Engine swap using Caravan motor. DIY with Pics
#61
There are HEMI and LS swap kits available for our JKs so all the electronics, emissions and everything else still works. A DIYer like yourself should be able to do it relatively at a good cost
#62
Have you looked into the GM LS engine swaps? That is in my long term plans for mine.
I really like the ls and hemi swaps but both motors would be a pain to work on in the vehicle and again I would be dealing with electronic trans and engine. Yeah they are pretty reliable but even just the kits are around 4k. I think I could do my entire engine and trans rebuild purchase price of the Fitech EFI and swap included for under $2500.
Here is a cummins swap I did a few years back into an F250. All in for that was around $2500.
https://www.youtube.com/watch?v=8Y8CeYfo9kc
#64
After looking further into it and this coming from a Ford guy. I decided that an LS would be a great swap. This is probably the ending of this thread and I will repost a new soon. The conversion probably won't be complete until spring time but I pick up my donor motor tomorrow. Not sure if I'm going to use a 4l60e trans or 700r4. Either way I think it will be an awesome useful thread. The budget for that will all parts bought rebuilt and installed will be under $1800. Then however much I can sell my current setup should make that number quite a bit lower. Here is the motor I'm picking up tomorrow.
$275 LSX 4.8. A little dirty and dingy but I figure do a full engine gasket set, $80. New lifters $100, water pump $45, alt $65, starter $65 use the Jeep P/S pump. Clean it up and it will be a great motor. It is going to be a sweet Jeep on an absurdly small overall budget. Probably not to many LS JKU's running around with less than 12k total including purchase price running around.
#65
Minivan 3.8 swap
FYI in 2007 Chrysler started using the same block casting number for the minivan and the JK Wrangler. I've got a 4.1 stroker Hanging on my engine stand I built using 505 Performance's stroker kit waiting to install into a 2008 Rubicon JKU.
#66
That's what I figured... I just picked the wrong year. Glad it's done either way.
#67
great stuff found out you can use 07-09 and change oil pan and timing chain cover
#68
Jeep miles
My 2007 jeep wrangler unlimited 3.8 liter has 257000 miles an 3/6/2021 It spun #4 cylinder connecting Rod bearing..No warning.. Never used a quart of oil between oil changes... Just started a knock..
#69
That 3.8 engine is a very stout engine - strong block, great valve gear but just a poorly designed rod bearing system and the oil rings are thin. Forged pistons and rod upgrade brings them to 100%. Then run a better cam and port the heads, better injectors and with higher compression one has a reasonable good power plant.
08YellowCat (03-26-2021)
#70
