JK belly protection
Once again I point out the weight factor. Anything you can do to protect and reduce weight I would suggest
I'm running the Rockhard Oil Pan/Trans skid and the Rockhard Evap. skid. Both give me peace of mind but honestly I've never tagged either.
However, the transfer case and gas tank skids are beat to hell. They're stock and they're holding up quite well!
i have to agree with RN M OVR. if you haven't seen our pics and/or videos, we have been wheeling the snot out of our jk at the tune of 2-3 runs a month over the last 2.5 years putting on close to 60,000 miles on the odometer - most of those playing on the rocks. to this day, i DO NOT have any aftermarket skids - NONE. yes, i have knocked off my evap 3 times only once required it to be replaced. of course, if you relocate it, you will not need to skid plate it. yes i have hit my oil pan - twice and enough so to dent it but still, no problems there. would i like a skid for it? yeah, but it's probably the only one that i want. as far as gastank, tranny or t-case goes, i have HAMMERED on the factory skids and they are holding up just fine. but hey, that's just been my experience...
Now I confess I push my JK to the limits (especially for a 4 dr) and have had it more than a few times in what a sane person would call buggy territory. But I do not feel that the stock skidding is in any way sufficient if you are going to push the envelope. I should point out that skids are far more critical on a 4 dr than a 2 dr. And that the more lift you have the less you should hit your skids. On the other hand the more lifted and built you are the more likely you are to tackle challenging terrain.
I would love to have more protection but I don't want the added weight. I have wheeled my Jk pretty hard and have banged underneath pretty bad. but I also look for good lines. So far everything is holding up pretty good. There are some great products on the market but.........WEIGHT!!!!
Or you do what we did three times this last weekend. Use a winch, a bunch of chain, and two or three snatch blocks (for multiplication of force and rediretion) and move the boulders out of the way. We were trying to open a trail that had been closed for decades. We succeeded. We're guesing that the largest were 5-8000 pounds.
I have to disagree with you on this issue. When I put skids on I went with RockHard and did the engine skid and the trans/TC skid and figured the stock gas tank skid would be sufficient. My engine skid has taken some good hits and my trans/TC skid is pretty scuffed up. But my stock gas tank skid is pathetic. It's bad enough that I've probably lost a couple gallons of tank capacity. I'm going to have to drop the stock skid and tank and take a rosebud to the skid and beat it flat with a 3 pound hammer. The tank should regain it's capacity and then I'll add the RH gas tank skid.
BTW - i'd just like to add for the record that the RH skids are great product that are very well made and if you feel that you really need the protection, they would be the way to go.
It all depends on what you want to do and how you drive. If you're planning on driving over rocks that are basketball sized and larger you may want to upgrade your skid plates.
The weight gained from adding full skid plates is significant but I've always found the sense of confidence out weighs the increase in weight and slight loss of mileage. If you think you're going to worry about every little scrape and bang then you may want to invest in skid plates. They will just allow you to have fun instead of constantly worrying about damage.
Oh, take a gander at the Skid Row products. I had some of their skids on another vehicle and they were top notch.
Good luck.
Good luck.
As to your first point; it does all depend on what you are going to do. To accomplish what we did this weekend we had to get a Jeep on the other side of a boulder so that it could turn around and winch the boulder downhill and to the side. The only way to do it was to climb and high center on what looked to be one of you basketballs; but about 3 1/2 ft tall. Got a Jeep up it, high centered, with no wheel haviing taction and two tires off of the ground and winched off dragging the undercarriage the whole time. He was well skidded so it was no problem. We got him turned around rigged thigs up and moved the boulder off the trail. FWIW there is a reason to carry two snaatch blocks! A lot of people may not do things like this but if you do skids are where it's at.
i hear what you're saying but, the factory skid did do what it was supposed to do and it protected your gas tank. sure, it may be dented quite a bit and enough so that you may have lost a couple of gallons in it's capacity... maybe, but, the skid did still protect it and it has prevented the actual tank from being compromised.
well, what do i know, i just like to play around at the mall
As an aside I have moved the Evap out of the way so that hasn't been an issue.
I never said you just like to play around at the mall!
But I sure know what my skids look like and I wonder what carnage I'd have suffered without them. Probably without them I wouldn't have done some of the things I've done. Maybe skids result in a bit of testosterone poisening!
testosterone poisening? now that is funny and something that i can see
Testosterone Poisening can be expensive!
