JK D30 Aussie Issues
Old Feb 18, 2010 | 02:05 PM
  #51
Screamin Lizard Customs's Avatar
Sponsoring Vendor
Originally Posted by ssunde1
Shit! And I thought I had finally made up my mind on an aussie.
Question for SLC, how far of a drive from baton rouge? Need gears soon and don't trust the 2 local 4x4 shops around here. Plus that would give me an excuse for a wheelin trip to tx.
We are between Dallas and Ft. Worth...Close to DFW Airport.
8hrs sounds about right in a Jeep
Sean
Old Feb 18, 2010 | 02:30 PM
  #52
ssunde1's Avatar
Sean
nice!! the ride from school to home is 11hrs in the jeep so i can def handle that. yall keep that $999 gear special goin for a while so i can make a trip over this summer and get some gears and an aussie up front please
Old Feb 18, 2010 | 03:20 PM
  #53
Alaska-HWY JK's Avatar
Default mkjeep
Did you use the blue washers from the JK specific Aussie Locker?
Old Feb 18, 2010 | 06:12 PM
  #54
mkjeep's Avatar
Nope..... I have a lockright, basically the same though.
Old Jun 1, 2010 | 06:47 PM
  #55
axsys's Avatar
Just saw this thread after having my Aussie installed for about 6 months. I figured that my clunking that many people are experiencing was just the ratcheting that was suppose to be noticeable after the install. I've been offroad a few times and the Aussie works great, it just freaks my passengers out when I make a U-Turn. I have a few extra washers laying around from my previous carrier, so I will try to run a tighter tolerance and see if it helps at all.
Old Jun 1, 2010 | 09:37 PM
  #56
axsys's Avatar
Originally Posted by ShortBlack
i wouldnt do that mate, keep it within spec. tightening the tolerances wont do anything to the ratcheting noise its just the way they are, thats why i turfed mine, didn't like it at all.
You dont want to get it to tight that it wont release at all! then you'll be in the shit
Mine is on the loose side of being in spec, I was going to try to tighten it up while still being in the spec range.
Old Jun 2, 2010 | 06:50 PM
  #57
joeydude's Avatar
While on the subject of Aussie Lockers... mine should come in on Friday... any tips before I go for the install... from what I hear its not too bad of a job?
Old Jun 2, 2010 | 07:35 PM
  #58
axsys's Avatar
When pulling the carrier out of the axle, mark every bolt and shim to make sure they go back exactly where they went. If you mix them up, you run the risk of changing your gear alignment.
