Jk wont start!! HELP PLEASE
Ok gents here's one for ya.. I need some help. When I turn my key on all my lights And connections work but when I try and turn it over I get nothing. Not even a click. I just put a brand new battery in it a week ago so I'm lost.
Quick check try putting battery power to the solenoid wire at the starter and see if the starter turns over than its probably the relay or something else if it doesnt turn over you need a starter.
Begin with this:
Open the fuse box. Have someone step on the clutch pedal and try to start the engine. See if you hear the starter motor relay click.
If you do, everything before it is good, and the problem may be with the starter itself.
Either way, a bad ground could be the problem.
