JKUR - Rock Krawler 1.5" Coils for 285/75/17s
Old Sep 18, 2014 | 09:48 AM
goofiefoot's Avatar
Default JKUR - Rock Krawler 1.5" Coils for 285/75/17s
After installing my Warn stubby front bumper and M8000 winch, I noticed a considerable front sag, adding to the factory rake. I checked my factory front springs and saw they are the 17-rate versions, which seems to explain the drop. I am wanting to run 285/75/17s (considering the BFG KM2s or the Nittos) to get as much tire as I can and retain the factory rear carrier setup. I am already running 1.5" spacers on the stock wheels.
I'd like to run the Rock Krawler 1.5" coils with Bilstein 5100s, front and rear, but was hoping to get insight on if this will help level the Jeep, as well as how much actual lift to expect. Also my daily driver, this is an expedition-centric jeep, so I'm not worried about any crazy rock-crawling, but I'd like to take advantage of the extra lift and flexibility. From everything I've read, this combination should clear the 285/75s with no issues, but should I consider longer bumpstops or brake line extensions? Should the front RK springs compensate for the extra weight, or might I need spacers to level the front? I have a hardtop, I'm carrying tools in the back, and have the Tuffy Security Deck, so my rear is laden fairly well.
I'd love some thoughts on this setup! Thanks.
Old Sep 18, 2014 | 09:54 AM
goofiefoot's Avatar
Adding another question:
The previous owner added a rear spring air bag setup to help with heavier loads. Adding the RK springs, should I even consider re-installing the bags, or get rid of them?
Old Sep 18, 2014 | 10:41 AM
Dahmer's Avatar
I have the 1.5 RK springs on my 2 door with front/rear metal bumpers, winch and tire carrier. I got about 2.5" lift maybe a little less but very close. You have a 4 door wouldn't get this much, but it was everything that I was hopping for I would recommend getting them.
I don't want to tell you to much about my setup since I have a 2 door and your will be a lot different. But I have extended brakes lines and shocks for a 4" lift. Front 2" bump stops no rear bump stops, flat fenders, and 35s.
Old Sep 18, 2014 | 06:45 PM
goofiefoot's Avatar
Thanks! I would love to get some insight from 4-door owners as well. I'd love to get 2" but I'd live with 1.5" and a nice, level Jeep.
Old Sep 18, 2014 | 07:05 PM
DunnyBunny's Avatar
JK-Forum Ambassador
If your wanting 2" then look into synergy 2" coils. Might have to do 1" rear cause I think synergy still has the rake.
Old Sep 18, 2014 | 07:20 PM
jadmt's Avatar
JK-Forum Ambassador
285/75-17's with 1.5" RK triple rates.
Old Sep 18, 2014 | 07:23 PM
goofiefoot's Avatar
Nice! That's exactly what I was hoping for. How much weight are you carrying, and how much lift did you net?
Old Sep 18, 2014 | 07:33 PM
jadmt's Avatar
JK-Forum Ambassador
I have a vr10000S winch on stock bumper with rockhard4x4 winch plate and a mopar front skid plate so up front I have about 100 or so extra pounds and back is stock bumper. my spare weighs about 85lbs. I got exactly 2" up front vs my stock 19 front springs and 1.5" in back vs my 60 stock springs. It rides and handles great.
http://s743.photobucket.com/user/jad...e%20Lake%204x4
Old Sep 18, 2014 | 07:34 PM
richlortz's Avatar
I got just over 2 inches, have a mid width bumper and winch up front. In the rear I just have tools and spares that I carry. The shocks are the bilstien 5100 for up to 3 1/2 lift with extended brake lines. Can run longer shocks but run into drive shaft problems. Very happy with what I have. Now just larger tires.
Old Sep 18, 2014 | 07:36 PM
richlortz's Avatar
Here are some pics on flat ground
ID:	576167   Click image for larger version
