Just level with me
yes i have rotated tires and even tried a different set of tires, still pulled right... I did not get a print out after the last alignment (I had someone do it after I installed and adjusted the control arms) they just told me the toe was off a little but I know the caster is like 3.5 or so.. I dont think it ever got back to the spec of 4.2 and 4.4
No, it's not. You want it square, right? As Mschneid said get an Adjustable Track Bar and that will make the tires sit perfectly square on the frame/under the body
You want it to drive straight, right? As foo.c said set the LCAs to the same length and check the toe.
Since you want it square and want it to drive right you need to do both.
I suppose I may have mis stated my intentions of this thread in the original post....
again thanks for all the help and sorry for the confusion... still learning!!!!!
