K&N Drop In Filter
Old Dec 17, 2009 | 04:44 PM
  #21
captjay's Avatar
change the oil and clean the filter and see what happens. if it does not improve then your bad gas milage could be many things such as wrong tire preasure, the way you drive, the fuel blend, the type of driving (ex. city or interstate), you could even go as far as mechanical problems with injectors, plugs, and host of others.
but start simple
Old Jan 5, 2010 | 11:05 AM
  #22
valeeum's Avatar
Originally Posted by drschem
The difference between 15 mpg and 17 mpg is just 2. Same as it is between 27 mpg and 29 mpg. It just seems worse when you're starting from a lower point. My point is, you really don't save enough money on fuel to matter.
Hey Guys,
Actually, in the former case, you're improving fuel mileage by 13.3% whereas in the latter the improvement is only 7.4%. So essentially, the 2 MPG improvement makes a much bigger difference to your wallet in a jeep than say a prius. I spend about $250/month on gas for my jeep. The 2 MPG would be equivalent to $33.33 in cost savings per month.
Thanks for letting me chime in!
Best,
V
Old Jan 8, 2010 | 06:05 AM
  #23
dellpjJK's Avatar
I spend 400-500 a month on gas... Is there a smiley face that shoots itself in the head?
Old Jan 9, 2010 | 03:02 PM
  #24
RA032726's Avatar
Banned Member
Default Pre-Oiled???
Thinking of buying a K&N air filter and was wondering if they come pre-oiled or do you need a cleaning and oiling kit for the initial install?
Thanks.
Old Jan 9, 2010 | 03:27 PM
  #25
bamjp1's Avatar
They come oiled. I love mine! Last air filter I buy for the jk.
Old Jan 9, 2010 | 03:31 PM
  #26
Bosox5's Avatar
Veteran: Coast Guard
Jebus!! I thought mine was bad!
Old Jan 9, 2010 | 07:09 PM
  #27
OFCRyan's Avatar
When I put mine in I saw an average of 15 around town with some highway and 17 on the highway. It did help though with the economy. I can't say much about the gas as I normally run midgrade in the summer cause its the same price as regular where I fill up. Hopefully you get it figured out!
