Leveling Lift?
If I understand you then a set of 3/4" spacers on the front coils will do the job, something like the Daystar spacers. I assume I can just rent the coil clams from an Autozone?
Rake is a term I'm unfamiliar with. If I had to put in aviation terms I'd call it pitch/additude. The JK seems to ride higher on the rear axel than the front axel giving it a slope from rear down towards the front. I don't know if this was done for visibility or to aid in water shedding from the roof.
who me?
with the right tools, i can do this by myself in about 15 min. if you are new to this and have the right tools, i'd say about 1/2 hour to an hour. the amount of space you have isn't really a factor but jack stands that are tall enough, a good floor jack, a 21mm, 18mm socket and wrench and a torque wrench that can go up to 150 ft. lbs. is something that you need.
2 hours if you don't take breaks or get interrupted! Disconnect the brake line fastners on the frame this will allow you to flex the axle down without damage. The ESP wires have a connector on the rotor that also pulls off to give you more droop without damage.
