Leveling Lift?
Old Mar 16, 2009 | 10:41 AM
  #21
Skippman's Avatar
Originally Posted by Calypso
Time for swing doors!
Ill run that by the condo association at our next board meeting.
Old Mar 16, 2009 | 10:57 AM
  #22
wayoflife's Avatar
JK-Forum Founder
Originally Posted by Skippman
It's not the opener, it's the door itself.
yeah, i hear ya. i installed a new sectional door and put in tracks that would allow the door to go all the way up and out of the way. in order to do this, i had to also use a tortion spring opener as opposed to a track.
Old Mar 17, 2009 | 11:57 AM
  #23
Skippman's Avatar
Ok, so I looked on TerraFlex's web site. ARe you guys talking about the $40 leveling lift?
Old Mar 17, 2009 | 12:22 PM
  #24
Calypso's Avatar
Haven't checked the site in a while but that sounds right.
Old Mar 18, 2009 | 06:23 AM
  #25
Skippman's Avatar
Ok, got it nailed down to 3 finalists.
1.) TerraFlex Leveling Kit 2007+ Wrangler - $39.99
2.) Daystar Comfort Ride ¾" Suspension Lift - $39.99
3.) Daystar Comfort Ride 1¾" Front & Rear Leveling Kit - $159.99
The first two appear to be bascially the same thing at the same price, although the Terraflex name carries more weight with me. The Daystar 1¾" kit would give me a bit more height without to much hastle. I do not want to do a complete suspension replacement/upgrade so the big boy kits are right out.
Old Mar 18, 2009 | 06:49 AM
  #26
joey2times's Avatar
the 1 3/4 ths is going to be a 1'' body lift with the spacer to level the rake.
at least thats what I would assume from the daystar 1'' bl kit and the 3/4ths leveling kit...
Old Mar 18, 2009 | 07:21 AM
  #27
JulianK's Avatar
What I did to level mine out was to first jack up the front and measure out the difference once it looked level. I ended up with 1.5". Looking here in the forum I noted that a couple of people used the 1.75" spacer quite nicely so I got one of those. Since I don't have a garage and it was winter I took it to Van & Truck World in Ottawa. Kirk (the Jeep guy) put in the spacer and lowered it for me to take a look at. It was a little too nose high so he removed the factory spacer (lowered it about 0.5"). Right now it's almost perfectly level. I'd lift it another 0.25" if I could but I'm just anal that way).
I didn't need an alignment, it drives like stock and looks way better! The best part is it cost me $60 labour in total!
It seems to me that some JK's are lower than others. I'd try the jack on the front thing first before picking out your spacer.
Old Mar 18, 2009 | 07:58 AM
  #28
Skippman's Avatar
Well, I was planning on putting on the MOPAR steel front and rear bumpers later this year so I wonder if that would bring the nose back down to level if I followed your plan Julian.
BTW, love the Dalek!
Old Mar 18, 2009 | 08:21 AM
  #29
[N]UGE's Avatar
If you do the bumpers and get a winch you will go down about 1/2inch
Old Mar 18, 2009 | 08:40 AM
  #30
Amway Man's Avatar
yep, we're talking about the same thing here. yes, 3/4" spacers up fron will do the job and personally, i like the spacers that teraflex makes better. as far as installation goes, no spring compressors are needed. simply place your jeep's frame rails on jack stands, support your axle with a floor jack, remove your wheels, disconnect your sway bar links from the axle, disconnect your shocks from the axle and disconnect the front track bar from the axle. slowly lower your axle until you can pull your coils out, remove the rubber isolators, install your new spacers, reinstall your rubber isolators and coils and reassemble everything else. make sure to tighten up your front track bar bolt to 125 ft. lbs. of torque with the weight of your jeep on the ground and you're done
Not to sound crazy but wouldn't it be a whole lot simpler to just rent the coil spring compressors and only have to take the tire off on each side to slide the coil in and out?
I don't have my JK yet so I cant say from experience how far down the spring retainer sits but it just seems like a lot less work than having to disconnect everything and re-torque it.
