Lift Concerns...
Old Apr 5, 2012 | 10:16 PM
Mark71's Avatar
Default Lift Concerns...
I have a 2008 unlimited Sahara automatic. I just purchased a RC 2.5 budget boost series 2 lift. I have already purchased 33's and 16" wheels but was waiting until next week to install the lift with the help of a friend that has experience with lift installation on the jk. After reading several forums regarding lifts and DW I'm a little nervous about installing the lift at all. This is my wife's daily driver and our favorite go everywhere in vehicle. Does this lift contain everything that I need in order to successfully complete my project without sacrificing safety or dependability? I'm just looking for a good stance with a little clearance no major off roading.
Old Apr 5, 2012 | 10:24 PM
Runewolf1973's Avatar
You can get Death Wobble in a stock Jeep as well as one that's lifted. I have a 4.5" lift and 35's and it is my go everywhere vehicle that I take my family and 3 kids in. Use quality parts, make sure the lift is installed correctly, and keep up on the maintenance is what I would suggest. You shouldn't have a problem. Death Wobble is extremely rare and preventable as far as I know. But I'm just a noob pretty much, so don't take my word for it.
Old Apr 5, 2012 | 10:27 PM
RufusTheTank's Avatar
I'm on the same boat, this is our dependable vehicule, but I hate the way it looks stock, this is the kit I bought, and i plan to get 33's for the stock rims but I'm also nervous to instal, don't want to ruin the smooth stock ride..
Old Apr 5, 2012 | 10:37 PM
Mark71's Avatar
That's true about the DW. I had a 98 Cherokee that developed it without any mods. Guess that's why I'm a little more concerned about the lift. I do stay up to par on all maintenance. Just looking for info on anything I can do to prevent it.
Old Apr 5, 2012 | 10:53 PM
Mark71's Avatar
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=300299"/>
Most everything I've read states that the ride will stay basically the same maybe just a little stiffer. Wondering if there are additional parts that I need or if this kit contains everything.
Old Apr 5, 2012 | 11:31 PM
StrizzyChris's Avatar
As long as you keep all your steering component bolts torqued properly you should have no problems.
Old Apr 5, 2012 | 11:32 PM
I think the kit is complete, I'm keeping my stock shocks, maybe down the road I'll upgrade..
Old Apr 6, 2012 | 12:16 AM
Mark71's Avatar
That's what I'm thinking. I do wish that I had gotten the adjustable front track bar. Wondering if the 1/4" shift will cause any uneven tire ware.
I guess this is all just newbie questions, LOL!!!!!
Old Apr 6, 2012 | 05:34 AM
rays0852's Avatar
Make sure you tighten everything up once its back on its feet. Check your mounts/bushings for your control arms, trackbar, tie rod, etc to make sure there is no play or wear.
You might look into a 9/16 bolt kit to replace the 14mm from the factory if you have any play in your suspension. Northridge sells them.
Old Apr 6, 2012 | 06:08 AM
BLK08JK's Avatar
x2 on this...
But with a spacer lift like you're doing you won't have any DW to worry about.
