Lift kit and wheels question
Old Feb 6, 2011 | 05:55 PM
Originally Posted by APOLIVY
Thanks for all the great replies. I'll go with the 2.5" BB and the 1.5 body lift.
Are there any additional components I will need to purchase to make this work. I've read about sway bars, extended brake lines, etc?
read WayOfLifes FAQ i posted above, it should have all your answers
If you are ordering the 2.5BB W/ 1.25 body from Rough Country, Contact a Rugh Country Vender on this fourm and you will get 10% off
Old Feb 6, 2011 | 06:06 PM
APOLIVY's Avatar
I read through the entire thread and found a lot of great information.
The only question I have left, since I was so convinced to go with a 4" suspension lift, would be the ride quality. Will the coil spring spacers make for a harsh ride? I'd like to keep the ride quality as stock as possible while running the bigger rims/tires.
Old Feb 6, 2011 | 06:23 PM
cosmec's Avatar
by running 35"s compared to the stock 31" tires theres gonna be a way different ride to the jeep. No way around it. Have you also factored in the cost of regearing?
Old Feb 6, 2011 | 06:33 PM
Air pressure has something to do with it and if you get the RC lift kit, it comes with new springs and shocks
From WayOfLife's FAQ
Q: I just installed a new suspension lift, why is my ride harsh, stiff or rough?
A: Assuming you installed new tires at the same time as your lift, there is a good chance that your tires have been inflated with a PSI that is too high. For optimal comfort and even tire wear. you should not run the recommended PSI listed on the sidewalls of your tires. Typically this will be way too much. On average for a 33" tire, I would recommend that you run your tires at approximately 28-30 PSI. For a 35" tire, I would recommend running approximately 26-28 PSI. For a 37" tire, I would recommend approximately 24-26 PSI.
Old Feb 6, 2011 | 06:41 PM
chipmaker's Avatar
Get the TF 2.5 coil lift. I have it and everything is in the kit that is needed. It rides like stock, and I have 35s underneath it. if you still wanted more height, you could add the body lift after...
Old Feb 7, 2011 | 04:01 AM
Rhino64's Avatar
If you're not going to wheel real aggressively I would keep it simple. A 2" BB with shock extensions with a 1" body lift and a quality set of disconnects. No drive line issues no need for a front end alignment and it will still have good road manners. I a sure you it will be very capable of handling pretty much all the terrain you will encounter and you'll have money left over . Just my 2 cents.
Old Feb 7, 2011 | 07:54 AM
Jkmedic231's Avatar
Newb question: c gussets?
Sorry, can't remember for the live of me what those are...
Thanks ::
