Limit straps ???????
Old Dec 8, 2011 | 06:44 PM
sick jk's Avatar
Originally Posted by dinojeep
It is a small piece of "L" shaped metal you mount to the spot where your coils sit. One screw holds it in. Very simple...and important
I like the sounds if that. You think there would be something holding in the springs from factory
Old Dec 8, 2011 | 06:45 PM
Rubichronic's Avatar
a retention clip, from what i understand, clips the spring to the axle and/or frame to keep it from falling out at full flex. i think this will also make the spring stop the down travel instead of the shock. I'm not sure if you put them on both the top and bottom of the springs though.
http://www.currieenterprises.com/CES...9.aspx?id=2852
Old Dec 8, 2011 | 06:47 PM
dinojeep's Avatar
Originally Posted by damon.l
oh boy. that makes me feel wonderful. im installing my rk 2.5 max travel kit this weekend.
Just call RK and have them ship you some spring retainers, don't know what they cost but it cant be very much.
As far as the rear is concerned I used a hose clamp, one on each in the rear, works great and almost free.
Old Dec 8, 2011 | 06:49 PM
dinojeep's Avatar
Yeah not needed stock as there is not very much travel, even disconnected.
Old Dec 8, 2011 | 06:51 PM
did you clamp the top or the bottom?
Old Dec 8, 2011 | 06:53 PM
sick jk's Avatar
I just want to eliminate the chance of a oversized slinky from rolling down the trail and to protect my new shocks.
Old Dec 8, 2011 | 06:56 PM
sick jk's Avatar
Originally Posted by Kevlarjk
Don't have pics and I don't have them yet The straps are primarily for saving your shocks. And some people use them to help keep their springs in place. If you have invested 800 bucks in a pair of nice shocks it's more like cheap insurance to make sure you don't have all the weight of your axles when disconnected sitting on your shocks. I am running a triple threat long arm my RK and at full flex with my fox reservoirs shock the spring is very loose. I'm not worried about the spring as much as I am damaging the valving in the shocks. And that's the point in limiting straps. And in someones case on this thread if your not disconnected and your springs are still loose then your shocks are way to long for your suspension setup. IMO. I'm sure some would agree and some would disagree.
Where did you install your straps? Did you weld on tabs , or just bolt them to an existing bolt. I heared people just run them to the shock bolts
dinojeep's Avatar
Anyone using limit straps ? And what's the advantage and disadvantage?
I actually have been thinking about looking into the limiting straps for my JK. Not for the springs but for the front drive shaft. At full flex my front DS boot does not hit the exhaust crossover( as long as its only one side flexed out). If I were to come into a situation where my front end was air born (even for a short second) my DS boot would drop on the exhaust crossover and it would rip the boot. Now, the type of wheeling I do this is not a huge concern but I have been thinking about it more lately.
Old Dec 8, 2011 | 07:00 PM
i think you can also fix the driveshaft issue an with aftermarket shaft.
Old Dec 8, 2011 | 07:04 PM
sick jk's Avatar
I don't have them yet. So I'm not sure what I'm going to do but I can tell you I won't be bolting them anywhere near the shocks. Those things are my pride and joy. And I can't have them even scuffed up. I think I'm going to find a nice location on the inside of the framerails behind each spring and weld a braket in there and on top of the axle. Flex it out to my desired length and measure what length I want to run and order them.
Haha. I know what your say'n Resivor shocks are sexy as hell. But if you wheel it they might just get scratched up.
