LoD Bumper Finished Bumper Pics
#22
JK-Forum Founder
Originally Posted by beachbum
I appreciate your reply, I'm glad to know the lights can be made to aim straight ahead, I'm also sure that you can weld something on the hinge pin to prevent the tire carrier from being removed, I just don't think you should have to, I'm sure this could be overcome with a little creative engineering on the manufactures behalf. I think it should be made so that when the tire carrier is swung open it could be lifted off the bumper, and when the tire carrier is closed it's locked onto the hinge pin, and could be locked on the other side where the latch is. It doesn't appear that the tool box locks either, in my opion it should, to me it's basically useless if I can't lock it.
Originally Posted by Archer
Eddie, I couldn't tell from the pics but I see a little rust on the bumper pivot point for the rear tire A frame. Is there a grease fitting on the A frame itself? Also in the little extras bag is there some sort of bushing that the A frame rides on so its not digging into the bumper as you swing it? Thanks
#24
Eternal ***erator
I do not see it in this prototype/prepaint shot either...
(although this one did answer my question about the weather seal. :sad: )
#26
Well of course there is a pin.That's what I thought the door was for. The angle of the shot hides enough square tube to also hide the pin location. I can't fathom it being behind the whole bumper. You couldn't grab just any off the shelf tongue and expect it to fit if that was the case.
#27
The way I see it, no weather seal means you got yourself an automated strap washer
Just drop muddy straps in drive two hours in the rain & voila! Slightly less muddy straps.
On the locking too;box note: Seems if you could lock the tire in the gate closed position, there whould be no need for a locking box. Can't imagine being able to steal anything thicker than a few sheets of paper if the tires in place.
#28
Eternal ***erator
Well, there is a good idea.
Ugh. I am getting lost.
- Make the tire carrier lockable.
- This would "lock" the toolbox area closed by default of the spare being in the way. (Assuming of course it is big enough to block opening it AND it is installed at the time, and has a wheel lock. If you get a flat, your toolbox wont lock)
- If the hitch pin is in the toolbox, it would not need to be a locking pin, assuming your spare is inflated, and installed, and wheel locked, and of sufficient size to keep it closed.
#29
JK-Forum Founder
Originally Posted by coyotesfan
It's not noticable in the picture, is there a hole on the inside of the reciever hitch to allow a locking pin to go though?
