Low-cost / Free mods that should be done?
Old May 30, 2012 | 09:27 AM
  #1221
Acer343's Avatar
^^^^^ I would also like the parts list if you would send a pm
Old May 30, 2012 | 10:21 AM
  #1222
Rip_Em_801's Avatar
^^^^^ Same please
Old May 30, 2012 | 11:26 AM
  #1223
DeucesALLin's Avatar
Originally Posted by MikekiM
This will absolutely happen if you install the Freedom panels without the rest of the hard top and don't flip the little feet things down.. The Freedom panels sit up on the lip of the hard top and without the feet things extended the panels sit much lower.
My bolts went all the way through my '07 Freedom top WITH the full roof.
Old May 30, 2012 | 12:09 PM
  #1224
NCC-2893's Avatar
I'm even more happy about my bolt trim mod after reading this.
Originally Posted by NCC-2893
This mod is so simple that it should make the list, and I don't think it's been mentioned on this thread yet. For folks tired of hand screwing for an eternity to get the freedom top hard panels off, you might want to shorten the length of screw by cutting it down in size.
Use a cutoff disk like a Dremel to cut 5/8 inch off the end.
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=297516"/>
Here's a comparison with the unaltered screw.
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=297518"/>
I know that some will post that the simple answer would be to ditch the screws altogether. This is for those who want peace of mind, or need the screws for a better water seal. I use a single shortened screw on the right panel only, because the left panel latch holds that one down with the right. Now the panels come off fast and remain secure when reattached.
Other notes: I could go shorter, but cutting off 5/8 inch seemed to be the sweet spot for me. 1/2 was not enough and still involved too much hand screwing. I looked for aftermarket solutions to this problem and found none. I also read on another thread that Chrysler purposely designed the long screw so that there would be no doubt as to whether or not it was threaded in place. I figure about 6-8 rotations would be enough to thread through most nuts. Anyone worried about security with a shorter screw, then just cut off less of the screw. Lastly, you'll be cutting off the tapered section of the screw head which may make it a little harder to thread, not an issue for me though. Enjoy.
Old May 31, 2012 | 06:52 AM
  #1225
dpowell5523's Avatar
Would love the parts list in both black and silver please?
Old May 31, 2012 | 08:49 AM
  #1226
freefly42's Avatar
I'd also love a parts list.
Old May 31, 2012 | 08:54 AM
  #1227
HELLBENDER-JK's Avatar
Has anyone got a parts list from this member?
Old May 31, 2012 | 09:28 AM
  #1228
Acer343's Avatar
I haven't ....
Old May 31, 2012 | 10:09 AM
  #1229
No not me either.
Old May 31, 2012 | 10:15 AM
  #1230
RufusTheTank's Avatar
Me either...
