Low-cost / Free mods that should be done?
Old Dec 21, 2011 | 12:19 PM
  #661
Bjbspong's Avatar
This may be a cheesy mod but it works great! I purchased two Husky keychain flashlights - the ones u can disconnect from keychain - and I attached them to each visor - the visors' lift when closed keeps them in place (no rattle etc) and when the visor is lowered they slide moreso than fall - and you can either direct your light or you can disconnect from keychain (about midway of black string) if you need the flashlight elsewhere; and when theyre not in use theyre hidden. u can get them at Walmart. Heres pic:
Old Dec 21, 2011 | 09:00 PM
  #662
Bosco109's Avatar
Originally Posted by bbrown626
Have you tried Ice synthetic wax or Mcguires Back to Black? I used the Ice on my '08 Corolla and it worked wonders with the black plastic.
Nope, but I did see a commercial for Back to Black a few weeks ago..... I'll try one of them this weekend. Thanks for the info!
Old Dec 21, 2011 | 09:28 PM
  #663
sringer's Avatar
If you get your flares coated in bedliner professionally...they are a ton easier to clean
Old Dec 24, 2011 | 01:17 PM
  #664
JeepinMedic's Avatar
So I am sitting at work today and while replacing some door handles on a few of the meat wagons I had a revelation! The heavy duty foam seal that adheres around the latches has a leftover square section that would otherwise be simply thrown away. I thought to myself that such high quality foam shouldn't be wasted and needs to be repurposed somehow. This foam has a super sticky backing. I am open to suggestions on the plethora of ways I can adhere it to my JK. At first I thought about making myself a headliner but am afraid that when the Oklahoma summer hits the foam backing would peel away from the top... I also thought about making myself a cush shifter knob... Is there any way to use it to get rid of the whistling of the top or to reduce the rattle of the two top bolts? Thanks for the suggestions and input! Merry Christmas!
ID:	254013   Click image for larger version
ID:	254014   Click image for larger version
ID:	254015   Click image for larger version
Old Dec 24, 2011 | 02:19 PM
  #665
SaFFFari's Avatar
Merry Christmas to u as well :-) if I had that stuff.. I'd stick it on the inside of one of these things.. May cut down some wind noise...
Old Dec 24, 2011 | 03:23 PM
  #666
dpowell5523's Avatar
What is that? It looks like a bug deflector for the hood.
Old Dec 24, 2011 | 03:25 PM
  #667
SaFFFari's Avatar
Wade wind deflector for the top... Eliminate some of the wind noise on the soft and Hardtop
Old Dec 24, 2011 | 04:24 PM
  #668
Bjbspong's Avatar
I added two pouches to the tailgate via running the straps behind the plastic wire harness; only store light items but its great! Here pic:
Old Dec 24, 2011 | 04:56 PM
  #669
JKCloak's Avatar
This would be great for sealing leaky door jams!
Old Dec 24, 2011 | 05:08 PM
  #670
Bjbspong's Avatar
I added seatbelt shoulder pads around door handles and handle above glove box for comfort (you have to stretch them a bit); and covered the softtop rubber for better appearance and it helps remove side window flapping. Theyre $3 a piece and actually blend great with interior; however, they catch the light in the below photos so they appear to stand out but they dont.
