Lug Nut Torque
Old Jul 24, 2008 | 05:33 AM
SH0RTBUS's Avatar
Originally Posted by JulietKilo
I work for a defense company also. But I bet you get paid a lot better then us Loadmasters.
The pay doesn't matter, we do what we do for the same reasons!
Old Jul 24, 2008 | 05:57 AM
nclehmann's Avatar
I installed my Spidertrax wheel spacers with 100 lbs of torque and then my wheels with 95 lbs. After a few hundred miles, I checked the Spidertrax spacer torque by setting my torque wrench to 95 lbs. None of the lug nuts moved. I reinstalled the wheels and set them at 95 lbs.
I've always used 95 lbs whether aluminum or steel. But I think anything between 90 and 105 is fine.
Old Jul 24, 2008 | 06:06 AM
sloppyjoe's Avatar
Wheels. Wheels. Wheels! THey r wheels..... Sry I know this is no help but they are called wheels. RIMS go on bikes, YO. JOE>
Heyspike's Avatar
To be honest I never torqued a wheel nut! That's almost 30 years of driving.........
Old Jul 24, 2008 | 06:17 AM
nclehmann's Avatar
How are you still alive? That's crazy!!!! Are you out of your mind? You probably don't check your windshield wiper fluid either! You're living dangerously!
(That was sarcasm, by the way.)
Old Jul 24, 2008 | 06:29 AM
Hilldweller's Avatar
Manual says 95 but Discount Tire's database said 110 when I put on new rubber.
I called the Jeep tech line and they asked at the factory; factory tech says that they torque them to 110 on the assembly line --- even though it says 95 in the manual.
I set my wrench to 100 and use a 2.5" extension that multiplies the torque a little...
Old Jul 24, 2008 | 05:30 PM
Heyspike's Avatar
I actually take good car of my cars, just never torqued anything.
Old Jul 24, 2008 | 07:55 PM
Big D2's Avatar
Originally Posted by SH0RTBUS
The rim material has nothing to do with the torque value. Torque values are based upon the bolt material and diameter. Proper torque values allow the bolt to be stretched within its elastic region, thus maintaining preload to prevent the lug nut from loosening. People seem to think that aluminum rims require less torque than steel wheels. You will snap the bolts long before you will significantly damage the wheel.
I agree with you 100%. My assumption was that we were talking about the 5.5 pattern for the Jeep.
Old Jul 24, 2008 | 08:21 PM
chuck45's Avatar
95# by torque wrench works fine. I imagine 100-105 would be fine too. No need to go higher in this application.
Old Jul 24, 2008 | 08:28 PM
MONGO!'s Avatar
X2 on the 95-100lbs.....I too have never torqued a lug nut until this Jeep. I guess my mind is set to 100lbs from birth.
