Metalcloak Thread
#1621
Impossible to answer, too many variables. You will need to cycle the suspension once they are in. Depends on bump stop and free length of shocks/coils. Ideally, you max out uptravel by adding tire clearance and then moving the shock mount up to almost fully compress the shock. If that is good and the coils don't unseat at full extension, you are good to go.
#1622
Which 5100's do you have? I feel like we've gone through this before but might be thinking of someone else. I'm running a similar set up with the 5100's for 3.5"-5" lift listed at like 11" travel part number 24-186872 for the front. I'm using stock upper mounts and nemesis brackets on the front, evo rock stars in the rear. I'm about 1/2" from maxing out the front, about 1" from maxing out the rear. 3" front and rear bump stop. This is what works for me. Cycle the suspension, see where you're at and make adjustments to get the most out of what you're running.
#1623
#1624
Just a durability update.
I have had my arms for about 2 yrs and 4 months. I have never touched them since I put them on. I have wheeled all across the U.S. Hawk pride in Alabama, some places in Mississippi and Tennessee, Superlift in Arkansas, SMORR in Missouri, Nevada, and lots of places in Utah.
Decided to finally clean and grease them.
Bushings still looked great.
Before tear down.
Next to a new bushing.
You can see they rotate in the ends.
Overall im super happy with the durability of them.
Before tear down.
#1627
I just installed the GC 2.5" ARB Edition lift on my 2012 JKUR. I am looking at installing the Rock Hard 4x4 Parts JK Oil Pan, Transmission and Dual Catalytic Converter Skid Plate. Does anyone else have this configuration? If so, are there any problems with clearance on the stock driveshaft?
Rockhard claims that "Our tests have shown stock drivelines to clear this skid at 40" of flex". That is probably with the stock suspension also. So it got me wondering about installing with the lift.
Personally my stock skids help up fine, i just added an oil pan skid. You could also move or skid your evap.
#1628
Been running my 3.5 GC arb edition for about 2 weeks now. Absolutely love it!
Still doing a little tuning - might dial in a little more caster. I just trimmed my fenders today - running 2" bump stops front/rear and it seems about perfect with my 37’s.
One thing I don't like, which has nothing to do with mc, is how the shocks get pinned up against the frame when one side is stuffed and the other is drooped. Looks like it puts a lot of side load and bends the shaft a little. Are there any mount relocations that move the axle mount outwards a little? Or am I fussing over nothing?
#1629
