Metalcloak Thread
#1701
I had waited till there was free shipping then pulled the trigger for the 3.5 ARB complete kit. With military discount.yes the instructions could use a little work. But if you study around beforehand, both on the MC site, and others you should be able to figure most out. I messed up the front brake lines, gave a call cause I was confused and got it straightened out right away. At the same time I asked about the sway bar arms. Mine are solid ( I have a JKUR) and the sway bar in front was pointed up. Was told that that is intentional to allow for flex. Have had it on for two months now and been up to Monarch CO. And also Silverton CO with the mod. Works great both on and odd road. Still running OEM tires until I can afford some 315/70/17 with new wheels. The wife was complaining about getting in so I solved the bro elm and installed Rock Slide stepper slider. Not cheep but now the wife is happy. So far they work great also. Solid and heavy as hell. Should be able to take a beating. Just need to instLl the led lights in them so it's easier to use at night.
#1702
2014 JKUR with MC 2.5 G-C ARB. With the above reference points, I netted exactly 3.69" in the front and 3.69" in the rear with stock bumpers, carrier, etc. Surprised, as I was hoping to eliminate the factory rake. I still have a 1" disparity front to rear.
#1705
One other thing i forgot about was that the directions are clearly for 2007-2011 JKs. There are a number of changes to components that I did not know about. First, you will not have to cut off the upper CA bolt on the passenger side. There is ample room to remove it. However, getting to those UCA upper bolts is a pain. There are heat shields installed that can and will cut you like a fish. lol. Ask me how I know.
? You just bend the heat shields out of the way. Wasn't a big deal on my '14.
#1706
#1707
FWIW... here's a couple of pics of my 2014 JKUR with MC 2.5 ABR + Nemesis relocation brackets + Racelines + 35" KM2's, wearing stock bumpers/flares/DS. Of course the front tires contact the front bumper with even the slightest stuff (while turning). No problems with factory trimmed pinch seam. Awaiting Nemesis Flares/Rockers + GenRight bumpers (need to be PC'd) and TW DS. The measurements I posted earlier were with doors, soft top and stock tire/carrier.
#1708
