Mirrors (yes this again)
Originally Posted by SBEII
For about the same money you can get the RR Quick Disco mirrors. I am much happier with them than I was my Harley ones.
Originally Posted by EsByrd
Could u run a die further up the shaft to create more threads? Could u post pics of the long stem mounted also cuz I'm thinking of doing this mod but I wanna find a way to make the passenger side viewable also
You can see the passenger side mirror perfectly with the long arm mirrors.
Originally Posted by newbiejeeper
Here is a pic for reference. If you figure out a way to add another half inch of threads these mirrors would be golden.
U could probably Polish down that lip on a grinding wheel then thread it higher and add a but to the top of the threads since u will no longer have a stop
Agreed that the aftermarket is weak at a solid take in this issue. Here is mine if it sparks anything in the DIY part of your brain.
This is a mirror from O'Riellys with a little bend in it. One bolt, one wingnut and everyone's favorite bedliner. I just throw it under the back seat when it's not being used.
I have the long stem ones too. If you center the mirror in the hinge and twist the acorn counterclockwise to get the threads to line up, then tighten it, you should be able to get it threaded just fine.
