Modded door handle write up
Old May 6, 2013 | 02:16 PM
GreenJK07's Avatar
So I know this is out there, but I really couldn't find a good write up on it. I decided to post this to show you how i did my door handles and how they turned out. Here is how to drill your handles. ***i am not responsible for any mistakes you make if you attempt this***
What you will need:
-1/2" bit & drill
-measuring tape
-old rag or shop rag
-razor blade
You have total of 4 1/4" of drilling space on each handle. I found center and measured in intervals to evenly space out the holes. See the template I made below for this.
Once you have your template made, mark the handles with the razor blade and get ready to drill. Make sure you have the rag behind the handle before drilling or it will punch through and get your paint. When you are drilling, make sure to hold the drill level to make sure you are making an even hole. Once you have your holes drilled, take your razor blade and clean the excess plastic away. That's it!!!
ID:	454939   Click image for larger version
Old May 6, 2013 | 02:26 PM
bobbyspaghetti's Avatar
Default Yup
Almost exactly how I did mine.
Old May 6, 2013 | 02:27 PM
GreenJK07's Avatar
They came out better than I expected. I think I may use a step bit and make the holes a little bit bigger.
Old May 6, 2013 | 02:58 PM
11rubiwannabe's Avatar
Is it just for cosmetics?
Old May 6, 2013 | 03:50 PM
GreenJK07's Avatar
Yes, just for looks. It's a copy from the "lower 40 jk".
Old May 6, 2013 | 04:19 PM
jbb609's Avatar
I really like this DIY, its Free easy and looks way better then stock. thank you!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!:thum bsup:
Old May 6, 2013 | 04:44 PM
mattyk's Avatar
Veteran: Navy
Thumbs up
heres a little tip i learned really quick when doing this a while back.
lightly wrap your hand in a rag and grab an old larger sized spoon to catch the drill as it punches through. once the drill be bites, it comes through FAST. this way you catch it in the spoon before giving the body side of your handles some extra scratched and dented 'character'
good write up and easy mod with great rugged look
Old May 6, 2013 | 05:29 PM
dahreno's Avatar
It makes your Jeep lighter so you can go faster and get better gas mileage . Duh !
Old May 7, 2013 | 03:42 AM
GreenJK07's Avatar
No problem. Glad to share my boredom and what others have done.
Old May 7, 2013 | 05:11 AM
Yuriy's Avatar
Sounds legit!!!!
