Mopar rear bumper owners... quick question
Old Feb 22, 2009 | 05:32 AM
DtownJK's Avatar
Originally Posted by roketman
Go to Lowes/Home Depot and get some ball cock washers to use as spacers. Someone had done a writeup on them. They work great to stop the shackle rattling. Plus they're cheap. I'm glad that they changed the hole size but they should have gone ahead and made the mounts beefier. Mine look like one good pull and they would come off.
Thanks for the info.
I will stop and get them today. I was out at Rausch Creek on Saturday and almost put them to the test but the guy behind me finally got out using a different line and some spotting.
Old Feb 22, 2009 | 11:13 AM
CIJeep's Avatar
Originally Posted by DtownJK
Here are some shots. Got the best price from the dealer believe it or not. Told them what I could get it for online and they beat it.
It was crazy how light the stock bumper was. 100% plastic.
Side where logo was:
Hope the photos help. It's a very clean looking bumper.
Would you mind posting a shot of the bumper from the side? Showing it close up like this photo? Seems the previous Jeep bumpers had visible overlaps at the ends. Thank you.
Old Feb 22, 2009 | 11:29 AM
DtownJK's Avatar
Like this?
Old Feb 22, 2009 | 07:37 PM
CIJeep's Avatar
Like this?
Yes, thank you very much.
Old Feb 23, 2009 | 05:35 AM
DtownJK's Avatar
Originally Posted by MaloCS
I've used the rear shackle mounts a few times (once at an angle) and they've held up great. Granted, I didn't yank on the strap but gently pulled.
PS - Could one of you guys post some pix of the bushings you're using to stop the shackle from rattling? Thanks.
Good to hear.
I am picking up some new 3/4 D-Rings today and when I get them on with the bushings I will get a photo posted.
Old Feb 23, 2009 | 08:12 AM
roketman's Avatar
This is mine with the ballcock washer installed. They are sold in the plumbing section at Lowes/Home Depot. Someone did an a piece in the writeup section.
No more rattle.
Old Feb 23, 2009 | 02:28 PM
DtownJK's Avatar
I stopped by and picked up the D-Rings at Quadratec today and bought the Ballcock washers at Lowes. 3 are needed. They were $1.59 each. I used one full washer and cut the other in half for the other side. 2 were to wide to fit.
Perfect solution thanks roketman
Old Feb 23, 2009 | 02:46 PM
YellowToy's Avatar
Just curious about the dimensions from an engineering stand point.
The shear strength of 36ksi steel is about 21.6 ksi (0.6*Fy). I can't tell how thick that steel is... 1/2inch?
So, the shear strength against tear-out will be
T=21,600lbs*2*(thickness)*(Distance from hole to edge)
If that's 1/2inch plate & the edge distance is 3/4 inches...
T = 21.6*2*.5*.75 = 16,000 lbs. If you use a F.S of 2.0 that would be rated around 8,000 lbs.
Old Feb 23, 2009 | 03:20 PM
DtownJK's Avatar
Those are just about right. 1/2" thick and just about 3/4" hole to edge.
I will have to trust you on your math I just had a few beers so I'm just glad I had enough motivation to go out in the garage and get the measurements.
