My one ton build / help thread!
35 spline, like dirtman said, is 1.5" diameter.
On a full float axle the wheels are attached the housing thru the bearings and hub. The axle shaft is independent and just turns the wheels. This removes the weight off the shafts and onto the stronger housing.
I wish I could get a list of everything I need to get for this axle... I'm trying to learn but damn...
Hubs
Wheel studs
Hub bearings
Rotors (I was told for this axle to find stock 75 Chevy 3/4 ton front rotors)
Calipers -- I have elderado calipers and pads
Hubs
Wheel studs
Hub bearings
