Need advise
Old Mar 16, 2009 | 09:12 AM
texastraveler's Avatar
Default Need advise
Wanted to know what the experts opionions are on lift?
2008 4DR X bought want to beef it up a little but mostly for looks will be driven on the road 95% of the time and maybe some light trails. Was thinking of doing a 2.5" BB and 1" BL with 33" tires. What do you think?
Old Mar 16, 2009 | 09:15 AM
wayoflife's Avatar
JK-Forum Founder
what you got listed is great except you can easily clear 35" tires and that's what i would recommend. 33's will look tiny.
BTW - welcome to JK-Forum.com
Old Mar 16, 2009 | 09:45 AM
SB08JK's Avatar
I you go 33" tires, you won't need the BL. If you run 33" tires, a budget boost or OME would be my suggestion. You can also get away with stock gearing easier with 33" tires vs. 35" tires.
I would also consider her age. If she is a younger teenager, I would say less lift is best if you are looking for looks. I would want to keep the center of gravity as low as possible while still making it look good. a 2" kit and 33" tires will do that perfectly.
Old Mar 16, 2009 | 09:46 AM
Calypso's Avatar
If you go with 33's I'd leave off the BL.
Old Mar 16, 2009 | 09:47 AM
Ramphog's Avatar
Go with the BB and the 33's.......
Old Mar 16, 2009 | 09:48 AM
Calypso's Avatar
Beat again!!
Old Mar 16, 2009 | 09:59 AM
Thanks for quick response and info. If I did decide to go with 35's would I have to do any other mod's such as gears? I'v read through a few post and seems like that is what everyone is saying. If so what is recommended and what is the cost in doing that?
Old Mar 16, 2009 | 10:07 AM
SB08JK's Avatar
you don't NEED to, but you should. It also depends on your stock gearing and if you have stick or auto. Keep in mind the gas mileage will hurt much more with stock gears and a 35" tire.
If you have auto, I would say you need to do it with anything less than a 4:10.
cost...about $600-$800 per diff for gears and install.
3:21 gears w/stick or auto...yes you will need to change
3:73 gears w/stick, you could get by but wont like it...with auto, I would change.
4:10 gears with stick, you will get by...with auto, it can work but you wont like it.
Old Mar 16, 2009 | 10:09 AM
wayoflife's Avatar
JK-Forum Founder
if you have a 6-speed, you can get by with the 3.73's and for your daughters purposes, it might even be better to have it on the slow side. if you have an auto, it will feel sluggish on long hill climbs on the highway but it's totally doable. honestly, i would recommend going 35's and i think you'll agree once you see everything come together.
TeraFlex's Avatar
Sponsoring Manufacturer
Welcome to the forum! Take a look at the TeraFlex 2009 Catalog, there's 6 different 2.5" kits for JK's there!
