Need alignment numbers.
2013 JK Sport 2-door. 18" Gladiator wheels, 275-70R18 33" BFG KO. 1.5" wheel spacers. Front lifted 2" with teraflex leveling kit. What are the new alignment numbers for front?
The camber and toe didn't change unless you bent or ran into something. The caster is lower that stock. How much lower? Don't know. At a guess, 3.5-3.7 (ish) instead of the stock 4.2. And another guess, the front axle is offset 1/4" to the driver side and the steering wheel is a degree or three off-center.
There is a DIY Alignment check in the Write-ups area. (index stickied at the top). Unless you go put it on a machine, that's about the best you're gonna get.
