Need alignment numbers.
Old May 12, 2013 | 06:50 AM
bimmerborn's Avatar
Default Need alignment numbers.
2013 JK Sport 2-door. 18" Gladiator wheels, 275-70R18 33" BFG KO. 1.5" wheel spacers. Front lifted 2" with teraflex leveling kit. What are the new alignment numbers for front?
Old May 12, 2013 | 07:02 AM
jeeperjkjeeper's Avatar
Exactly what #'s are you talking about?
Old May 12, 2013 | 02:23 PM
bimmerborn's Avatar
Front wheels alignment numbers for Camber and Caster
Old May 12, 2013 | 02:37 PM
kaptkrappy's Avatar
How exactly do you plan on adjusting your caster and camber ???
You can only adjust the "toe in/out" with your suspension.
Old May 12, 2013 | 04:00 PM
nthinuf's Avatar
The camber and toe didn't change unless you bent or ran into something. The caster is lower that stock. How much lower? Don't know. At a guess, 3.5-3.7 (ish) instead of the stock 4.2. And another guess, the front axle is offset 1/4" to the driver side and the steering wheel is a degree or three off-center.
There is a DIY Alignment check in the Write-ups area. (index stickied at the top). Unless you go put it on a machine, that's about the best you're gonna get.
Old May 13, 2013 | 05:52 AM
bimmerborn's Avatar
That's the info I was looking for. Thank you!
