NEED HELP front axle noise!!
Old 07-22-2014, 07:30 PM
FlexyJK's Avatar
Originally Posted by 5150cliff
I have the solution............take the PR44 off.......give it to me and I'll give you my stock 30. Solved, no more noise!
Tempting. But I think I have found the issue. Looks like front pinion seal dust cap is loose. Hopefully it won't chew anything up.
Old 09-08-2014, 01:01 PM
aapfelbaum5's Avatar
It looks like you need to re torque you pinion flange nut. remove the front driveshaft bolts and the nut is a 1 1/8th. this should fix your issue.
Sent from my iPad using Tapatalk
Quick Reply: NEED HELP front axle noise!!
