Need help light bar
Old Feb 19, 2012 | 05:03 AM
jab1472's Avatar
Default Need help light bar
Need some input i am looking in to getting Rigid E-Series 50" LED Light Bar & JK Light Bar Mount from poison spyder site but i have rugged ridge mirror relocation set up and it looks like they will be in the way of the light bar mount any one have ideas how i can run with both on my rig?
Old Feb 19, 2012 | 02:06 PM
jab1472's Avatar
ID:	279936Click image for larger version
Name:	Relocation Brackets.jpg
ID:	279937 here are some pics
Old Feb 19, 2012 | 06:44 PM
Acer343's Avatar
Put the light bar on first than the mirror will fit
Old Feb 20, 2012 | 03:48 PM
jab1472's Avatar
won't the bottom of the light bar stick out to much?
Old Feb 20, 2012 | 03:52 PM
fadeout's Avatar
it's about 1/4" thick so nothing really noticeable. But you will need a rubber spacer of some sorts to make it work correctly. And you may need longer bolts, I had to use longer ones when I stacked A pillar mounts over the poison spyder mount.
Old Feb 20, 2012 | 04:37 PM
jab1472's Avatar
Any pics? Where is the best place to run the wire in to the jeep?
Old Feb 20, 2012 | 04:55 PM
fadeout's Avatar
Haven't really gotten around to taking decent picks yet since I just installed it 2 days ago. The wiring is kind of a bitch to hide you can tuck the connector piece up on top behind the bracket that holds the bar up and the wiring tucks away behind the actual bracket itself. I cut away the thick black covering to make it easier to hide away, its not gonna affect the weather proofness of the wiring at all.
