NP242 in a JK?
Old 06-14-2013, 05:34 AM
  #21
AirJordan613's Avatar
Originally Posted by Wizzo Poland
Guys,
has anyone actually tried to swap the jk transfer case for the 242 (or 242hd)? I was told ther isn't enough room to fit the box in the jk. I am seriously considering a JK instead of my old Wj but the lack of 4HI got me worried. The european JK with the diesel engine and auto box has a very uneaven torque output and the back wheels keep on spinning any time you step harder on the throttle. I can't imagine any winter situations with the current transfer case. On the other hand both the 242 and my Wj quadradrive box work just fine when things get slippery so my question is really can you have any of them in a JK Unlimited?
The JK has 4-hi. It handles the winter very well for me.
Old 07-19-2013, 01:04 PM
  #22
tomharley's Avatar
Guys,
I did this swap! I have use T-case out of KJ 03. Fits well but a little works is necessary.
ID:	479701 Click image for larger version
ID:	479704 Click image for larger version
Old 07-19-2013, 01:10 PM
  #23
desync0's Avatar
Details! Write up a how-to, I've decided to keep my JK for awhile and this is tops on my list of mods!
Old 07-19-2013, 01:58 PM
  #24
tomharley's Avatar
It will not be easy to describe. My English is not so good. And this is a little more complicated theme in my own language.And,only five photos per post.
The main problem is of length,. NP242 is too long, and has a slip yoke instead fixed yoke ,if you want to use stock drive shafts. No one manufactured SYE kit with short shaft.
I have long thought up that model NP242 use. Finally it became the best NP242J from KJ Liberty. It has the same input shaft, same length. It has 32 ​​teeth front and rear outputs and the same position switch. It is important for the proper function of the ESP.
First:
shorten the main shaft. Spline length -1,25" (32mm),drill and tap thread 3/8 or 10mm.
Then make washer and weld it to the inside of yoke.
ID:	479726 Click image for larger version
ID:	479728 Click image for larger version
Old 07-19-2013, 02:21 PM
  #25
tomharley's Avatar
second:
modification of range selector
The position switch is the same. Five positions. NP241 only skips the position of Full Time.
The value in position Full Time in the Selec Trac,JK's electronics does not know. It is necessary to weld on a little a bit material on the third surface of range selector. The switch must be in this position to give the same value as in the 2WD position.
stock 242
Modified
2WD
Part Time
Full Time
Neutral
0,21
Lo Range
0,06
Travis Patton (12-26-2020)
Old 07-19-2013, 02:32 PM
  #26
tomharley's Avatar
Last, but still not resolved. It is necessary to rotate the direction of the shifting. Everything works, only the lever is backwards in 2WD and shifting is forward.
ID:	479736 Click image for larger version
Old 07-19-2013, 02:45 PM
  #27
tomharley's Avatar
Even after this modification, the new t-case is longer than Command Trac. It's not a problem for JK Unlimited but I do not know how the 2dr.
241 - 14,56" (370mm)
242 - 17,70" (450mm)
Old 07-19-2013, 02:58 PM
  #28
Tooadvanced's Avatar
What tcase they using in new grand? Get that its awd and they put behind hemi so should be strong enough (unless differ for hemj) but none the less grand has same engine and tranny and I've seen em wheel them through moab and the rubicon
Old 07-19-2013, 03:02 PM
  #29
tomharley's Avatar
Here's a nice overview
Jeep Transfer Case Rebuilt Quality Factory Transfer Cases, Save Money! - Drivetrain.com
Old 07-19-2013, 06:31 PM
  #30
desync0's Avatar
Thanks for write up! You basically had to make your own slip yoke eliminator.
I dunno how well the extra length would work in my 2dr :(
Either way, bookmarked for when the warranty runs out lol
Quick Reply: NP242 in a JK?
