Off Road Evo Rock Star Skids, Whose got em'?
Old May 13, 2010 | 12:15 PM
runit3's Avatar
Default Off Road Evo Rock Star Skids, Whose got em'?
I'm in the process of completely armoring out my Front and Rear D44's with Evo products. Shopping cart has 44magnum tubes, front LCA skids, C2-Gussets, and now I'm debating between the rear LCA skids or the Rock Star brackets.
For those that have the Rock Star Skids how easy was the install (says "bolt on" on site, but then notes cut/grinding req.) and were there any issues with a 4" lift shock? They look a lot beefier than the rear LCA skids. More ground clearance/articulation sounds nice too
Old May 13, 2010 | 12:28 PM
sm_rubi's Avatar
Originally Posted by runit3
"...For those that have the Rock Star Skids how easy was the install (says "bolt on" on site, but then notes cut/grinding req.) and were there any issues with a 4" lift shock? They look a lot beefier than the rear LCA skids. More ground clearance/articulation sounds nice too
We are running them, easy install...what you mention is the cutting off of the extra long lower shock mount point which isn't hard. We are running them with the 4" ORE Plush Coil Springs and King 2.5 shocks.
Love the extra clearance they provide articulation is awesome as well!
Behind the Rocks - Moab
Downward droop
Old May 13, 2010 | 02:14 PM
sm_rubi's Avatar
Originally Posted by bcrouse
your brakeline looks a bit snug in that picture.....hope its just the angle of the picture....
Yeah it's the angle of the pic...they're actually pretty long. Had some issues with wheel bs and the extended front lines after going with the front coil overs (especially the abs lines) getting cut...I couldn't get spacers prior to EJS but all is well now front and rear.
Old May 13, 2010 | 02:22 PM
Firefighters_Axe's Avatar
Sweet pics
Old May 13, 2010 | 02:34 PM
Robar's Avatar
EVO JK Rock Stars
Old May 13, 2010 | 02:42 PM
runit3's Avatar
So are they worth the extra $ in comparison to the Rear LCA skids?
Old May 13, 2010 | 02:43 PM
Suffolk JK's Avatar
I have them, took about an hour to install. With 3.25" of total lift (TF pucks) I'm running stock shocks. I don't have a rear swaybar and at full compression and extensions, there's about half an inch left of travel both ways. Non extended bumpstops on the rear. GREAT flex.
Old May 13, 2010 | 03:47 PM
UGOTKERN's Avatar
Get the rock star skids. One of the best mods we did. Used to always get hung up and smash up the OEM shock housing and the bolt that holds them in. Now we hardly come close hitting anything.
Old Mar 18, 2014 | 11:15 AM
SabrToothSqrl's Avatar
Default nice
these look sweet, anyone have any install pics like before, during, after?
My rear sway bar has been lowered at the frame due to my lift kit, this would let me get it back up to where it belongs, and add rear ground clearance.
Anyone have any issues with all that drop and the factory rear driveshaft?
I already have extended brake lines all the way around...
Old Mar 18, 2014 | 11:19 AM
ronin2120's Avatar
Vet Army
When I did the rock star skids I also did the Synergy upper shock relocation brackets. Easy install especially if you weld them. Posted the only pics I have.
ID:	538596   Click image for larger version
