Offset Ball Joints
I'm fairly sure that my axle Cs are bent. If you look straight from the front, the front tires lean in at the top compared to the rear. I intend to gusset up the Cs but looks like the damage is done. I've read that offset balljoints correct the camber lean. Has anyone replaced the ball joints with offset ball joints? Can the C's be bent back at an axle repair shop or are most people living with the camber?
