Offset Ball Joints
Old Mar 10, 2009 | 07:04 PM
RCJeeper's Avatar
Default Offset Ball Joints
I'm fairly sure that my axle Cs are bent. If you look straight from the front, the front tires lean in at the top compared to the rear. I intend to gusset up the Cs but looks like the damage is done. I've read that offset balljoints correct the camber lean. Has anyone replaced the ball joints with offset ball joints? Can the C's be bent back at an axle repair shop or are most people living with the camber?
Old Mar 10, 2009 | 09:52 PM
CIJeep's Avatar
You can use a level on your tires to see it they tilt in like you say. Are you sure your tubes aren't bent?
