Old Man Emu Suspension Setup
Old Jan 27, 2015 | 07:32 AM
TheDirtman's Avatar
They are bushwhackers and not trimmed. Tires and the fenders were the first mods I did on the jeep.
Old Jan 27, 2015 | 07:35 AM
Stubicon's Avatar
Dang they look spacious.
Old Jan 27, 2015 | 07:44 AM
TheDirtman's Avatar
here it is with no lift.
Old Jan 27, 2015 | 08:43 AM
Tilly's Avatar
I ran both the HD and and no load coils on my 2007 JK, the HD gave me about 3.5" of lift, the no load ran about 2.5" and rode much nicer. I was running their nitro sport shocks at the time and was pleased with the results and ride quality. I had a warn 8000 winch and a heavy steel bumper. here is a shot with the HD coils with bushwhackers and 33" tires.
Attachment 593852
Sweet setup. Did the no load coils make your jeep level or did you have some foward rake? Would the no load coils minus about a half an inch still give the suitable advantatages of a lift? I need the ultimate on/offroad jeep.
Old Jan 27, 2015 | 08:49 AM
Stubicon's Avatar
Nice. Here's mine next to a co workers. Flats give tons of room.
Old Jan 27, 2015 | 09:06 AM
TheDirtman's Avatar
I never had an issue with rake and could not tell you for sure if it had rake or not with the no load but the ride was much better.
Old Jan 27, 2015 | 10:45 AM
jadmt's Avatar
JK-Forum Ambassador
Attachment 593897
yes here is 1.5" lift with 35's.
Old Jan 27, 2015 | 04:50 PM
Tilly's Avatar
Cool thank you for the help!!
Old Jan 27, 2015 | 07:15 PM
Mr.T's Avatar
Community Favorite
There's some OME info in the build thread in my sig -- note that it's a 2-door. The OME trim spacers are good for adjusting height, or to compensate for added weight.
A thought on the rake, naturally the back end squats down as weight increases on the rear axle. The spring rate on mine is 320 lbs per inch (both rear springs combined), which is stiffer than stock. Mine easily varies an inch in the back depending on cargo/passengers.
Cheers!
Old Aug 12, 2024 | 02:10 AM
Royters's Avatar
Attachment 593852
Thats interesting to know. Do you remember if the HD springs were OME 2615 front OME 2617 rear? These have the same spring rate as the LD OME 2626 front and OME 2630 rear, they are even exactly the same specs (weight, springrate, turns, thickness, etc..) but have between 0.5" to 1" greater freelength. Maybe since it gave you 3.5" lift the shocks were not working at optimal performance causing the stiffness?
