ome
I have been told the stock bumpstops are fine with the OME. *Note I'm using the OME shocks that came with the kit. If you're not using the OME shocks, then that could be a different story.
But if you have too big tires, you maybe could use them to eleminate rubbing
i have the ome shocks front and rear.
if you have the stock bumpstops i would think almost any large tire would hit, wouldnt they? that puts the centerline of the axle in the same spot as the stock spring.
