OME bowed/bent spring
Old Apr 22, 2008 | 11:09 AM
derekls's Avatar
Default OME bowed/bent spring
I contacted ARB, they said they would replace my spring if it fixed my problem, I sent pics and waiting a reply from them.
The axle is centered now, and it appears to be seated right? You guys have any suggestions?
Here are the pictures:
And finally a drivers side spring pic for reference:
Old Apr 22, 2008 | 11:19 AM
derekls's Avatar
by the way I did take it back to the dealer who installed it and he tried to reclock the spring and it didnt help, but perhaps he was doing it wrong?
If it looks like it is seated wrong, let me know how I can tell the shop guy how to fix it or I will do it my self either way.
Should it hurt the spring riding on it like that?
Old Apr 22, 2008 | 11:25 AM
RedneckJeep's Avatar
Coil springs usually have an indention at the end of the groove where they seat to hold the end of the spring. The bottom side looks good. Since you didn't take a pic of the inside of the spring seat on top, it's hard to tell. If the spring is removed and it straightens out, it's likely not going to do any good to replace it, because something else is causing it to sit crooked. Dumbass question here.....are you sure the spring is not installed upside down?
Old Apr 22, 2008 | 11:28 AM
derekls's Avatar
not a dumb question at all...but to be 100% with you i dont know.... But I think it is because isnt one side bigger than the other ........ maybe someone else can look at it on here and tell for sure?
and the second picture is the pass side seated up top...the best pic i could get of it
It was installed at my dealer
Old Apr 22, 2008 | 11:32 AM
Offroadme's Avatar
it does not look like it is upside down but it's hard to tell from the pics.
Old Apr 22, 2008 | 11:33 AM
derekls's Avatar
i think one end is bigger than the other so wouldnt it be obvious which end goes where?
Old Apr 22, 2008 | 11:43 AM
derekls's Avatar
If I disconnect and flex it a bit would it straight up or do I need to fix this before i wheel?
was thinking about going to windrock today and play around but dont wanna f anything up
Old Apr 22, 2008 | 11:44 AM
Dustoff '68's Avatar
I don't know what to look for....
Old Apr 22, 2008 | 11:45 AM
chucktuna's Avatar
If those are OME springs, then (at least) the one spring with the pic of the bottom seated on its grove is NOT installed upside down..
I just installed mine ( pics coming) and there is no way it could be seated and be the wrong end.
BTW...no bowing on my 4dr...sux to be U
chuck
Old Apr 22, 2008 | 11:48 AM
derekls's Avatar
centering the axle helped it a little bit, but didnt 100%
