OME bowed/bent spring
Old Apr 22, 2008 | 12:08 PM
Northridge4x4's Avatar
Sponsoring Vendor
This is the first we have seen with OME.
If you look at this picture it looks like the factory isolator is crushed. Just a thought .But this will cause it
Old Apr 22, 2008 | 12:10 PM
upper mount doesnt looks like its seated right
is it in the "Groove" on the frame mount??
hard to tell from pics
Old Apr 22, 2008 | 12:13 PM
Chukronos's Avatar
Originally Posted by RedneckJeep
Dumbass question here.....are you sure the spring is not installed upside down?
That is what I was thinking as well. Not sure though. The bottom of the spring looks smaller than the driver's side.
Old Apr 22, 2008 | 12:17 PM
chucktuna's Avatar
no way.
see my springs before install.
they are upside down in my pic so as to sit up..chuck
Old Apr 22, 2008 | 12:24 PM
Big Clint's Avatar
Check the top isolator. Can't tell in the picture, but I noticed after I installed my BB that I had to re-seat one of the front top isolators, and re-seat one of the rear coils on the spacer. Seems they settle into (rather out of) place if not exactly right when weight is put on them.
I think the front top isolators need to be spun around so that the original coil imprint aligns with the new coil.
And they are not upside down. The ends are definately different sizes and the installer should have noticed something way off if trying to put it on upside down.
Old Apr 22, 2008 | 01:18 PM
RedneckJeep's Avatar
Originally Posted by derekls
not a dumb question at all...but to be 100% with you i dont know.... But I think it is because isnt one side bigger than the other ........ maybe someone else can look at it on here and tell for sure?
and the second picture is the pass side seated up top...the best pic i could get of it
It was installed at my dealer
I'm not sure as I haven't seen a pair yet. It is not uncommon though for front springs to be the same diameter top and bottom, but they will usually fit correctly only one way.
Old Apr 22, 2008 | 01:21 PM
Originally Posted by chucktuna
no way.
Then that answers the upside down question. I would start to look at the spring seat at the top, then, as others have suggested. If the bottom is installed correctly, that's where the problem has to be.
Old Apr 22, 2008 | 02:32 PM
derekls's Avatar
How do you fix this problem?
Old Apr 22, 2008 | 02:33 PM
Sponsoring Vendor
Take the coil out and reinstall it correctly.
David
Old Apr 22, 2008 | 02:57 PM
derekls's Avatar
David
got pictures of this the way it is suppost to look? and pictures of the install so i can show them to my dealer
if the dealer installed it wrong they will fix it for free............... if its a faulty coil and they take it out and try to reinstall..no fix.. ill be paying them again, which is fair but also sucks on my end
